Старый 19.08.2019, 22:55   #3
Hi.
To find pinout of VAF we typically remove it's plastic cover and watch directly on a board.
First we see the signal from the flap - you see there a slider and it is not difficult to find on what pin it goes.
Next you will see some wires from IAT sensor - one of them is signal - it goes directly on some pin of the VAF's connector. And other wire is connected in parrallel to some pin which is also connected to the ceramic resistive board - this is a GND( ground).
And the last available pin will be a 5 V reference voltage.
If it possible, please attach a photo of your VAF with removed plastic cover - so we can see a slider and a ceramic board - i'll try to show you on this pic.
Часовой пояс GMT +6, время: 20:04.
