Hi JCF,
I checked logs from msg#5 - it is ok in general. But i see a spikes on oxygen sensor signal. Let me know from which point did you take supply ground of the converter? Also please check ignition system totally - high voltage wires with a multimeter and set spark plug's gap to 0.85-0.9mm . Also check ground wire from chassis to engine/gearbox. And let me know how much wires goes from oxygen sensor - 1, 2, 3 or 4. |
